Re: 786 vs. 886
Posted by Josh H on November 18, 2005 at 10:39:25 from (128.118.79.216):
In Reply to: 786 vs. 886 posted by Mike in Vt on November 18, 2005 at 05:59:21:
I am a fan of Farmalls but I am a pretty big fan of Oliver/White too. The 2-85 is a decent tractor and is likely cheaper. I've never had experience with a 786, but the 2-85 can hold its own. I've heard it said on this board that an 80 hp farmall can pull with 100 hp tractors of other brands, but I believe the Oliver/White tractors were the same way. They are pretty common, parts are available easily from agco, and it is a proven design. I wouldn't rule out the white just yet, try them both out.
Josh H
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
