Re: 786 vs. 886
Posted by Hugh MacKay on November 18, 2005 at 14:44:26 from (209.226.106.191):
In Reply to: Re: 786 vs. 886 posted by Josh H on November 18, 2005 at 10:39:25:
Josh: I have to agree with you, parts for White, Oliver or Cockshutt are surprisingly easy to find. They will also be a close match in the field to Farmalls in the same hp class.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
