Farmall Tractors Discussion Board
Re: More C Hydraulic Questions
Posted by leslie on December 30, 1999 at 19:03:25 from (206.28.174.142):
In Reply to: More C Hydraulic Questions posted by Brian Schmidt on December 29, 1999 at 20:36:04:
I think what you are refering to is called a check valve. These are available from most hydraulic houses. If you do not use one of these valves the hitch will not hold the position.
Post A Followup
: Re: Re: More C Hydraulic Questions
