Farmall Tractors Discussion Board
Re: Super A Stripped Threads on Coolant Drain
Posted by Steve T on December 30, 1999 at 19:07:39 from (208.150.193.38):
In Reply to: Super A Stripped Threads on Coolant Drain posted by Chris on December 30, 1999 at 19:01:01:
My sugestion, for what its worth, is to drill it out to the next size up and re-tap it that size. Install a reducer bushing with a liquid type thread sealant on the outside of threads, and tighten as hard as you dare. then you can use a regular pipe plug, or install a drain valve in it. If Im correct, the original plug is 1/4in.
Steve T
Post A Followup
: Re: Re: Super A Stripped Threads on Coolant Drain
