Re: Piston ID
Posted by gene bender on November 19, 2005 at 04:33:53 from (66.43.221.81):
In Reply to: Piston ID posted by Dave H (MI) on November 17, 2005 at 17:11:39:
There were several different length of the extensions at the end of the piston throw. Before you get some more cycls better make sure you have the correct total length for the imp you are using it on. Plows and discs used a shorter one that you have pictured although you can always saw the end off to make it work. They all had the same stroke which was standard 8in movement. Ones on cotton pickers were realy long.
Post a Followup
