Re: Super C throttle adj.?
Posted by gene bender on November 20, 2005 at 04:33:04 from (66.43.221.81):
In Reply to: Super C throttle adj.? posted by Andrew Z on November 19, 2005 at 15:38:36:
Did you fix the wobble of the input lever when you had it apart? With engine off remove the pin in the clevis going to the carb. Now open the throttle linkage wide open. The pin for the clevis should go back in holding the carb open fully. If not adjust clevis. These two things should end your problem.
Post a Followup
