Re: Farmall Super A hydro
Posted by Hugh MacKay on November 21, 2005 at 11:33:07 from (209.226.106.178):
In Reply to: Farmall Super A hydro posted by fenton on November 21, 2005 at 03:53:49:
fenton: I think you have to unbolt the lines at both ends. They are just to rigid for the pump to come out by. There will be a gear on the shaft that is driven off the timing gears. That pump will have to come straight out for about 1.5" give or take a bit.
If you have hydraulic oil leaking from system into crankcase the seal on pump shaft is your problem. I've never had one of those apart. You should have some discussion with some others, CNKS is one guy I can think off hand, with experience on those. Some of those are quite simple to fix and other more difficult.
Post a Followup
