Re: CUB lift capacity
Posted by Jack in OH on November 21, 2005 at 12:23:01 from (192.91.171.36):
In Reply to: Re: CUB lift capacity posted by Dellbertt on November 21, 2005 at 09:03:24:
If I recall correctly, the factory spec is 300lbs. I put 2 rear wheel weights(150lbs. each) on the rear lift of my cub during the winter for traction while plowing snowand it lifts them OK.
Jack
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
