Re: CUB lift capacity
Posted by Dellbertt on November 21, 2005 at 09:03:24 from (204.39.209.213):
In Reply to: CUB lift capacity posted by Kevin (FL) on November 21, 2005 at 05:32:38:
There are many factors that can very the lift-strength of any hydro system. Size of pump, lines, cylinders, reg, valves, frame, if you are pushing or pulling.........
If you are just building a rake then all you are lifting is the rake....not debris.
I would make sure you make your push-frame against the rear housing.
Get some specs from you friendly IH dealer. (IF there is such a thing)
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
