Re: M runs poor at high rpms
Posted by RustyFarmall on November 21, 2005 at 21:06:28 from (207.32.13.223):
In Reply to: M runs poor at high rpms posted by TYE W on November 21, 2005 at 19:19:06:
Your carburetor is set too lean. The load, or high idle adjustment screw should be set 3 full turns out, and your particular engine may require another 1 or 2 turns out. Did you check the carb float level? Are you getting sufficient fuel to the carb?
Post a Followup
