Re: Red hot resistor
Posted by Bob M on November 22, 2005 at 04:56:53 from (151.190.254.107):
In Reply to: Red hot resistor posted by alannpa on November 22, 2005 at 03:41:15:
That’s not good! Sounds like either the switch is wired up wrong or (long shot possibly) the 4 position switch has gone bad.
Has your tractor’s original wiring been modified? I.e. has the original cutout relay been replaced with a voltage regulator, or has a 12 volt conversion been done? If so there should be no wiring connected to the field resistor. Only with the original cutout setup is a connection made to the field resistor.
Post a Followup
