Re: Firing up a MD
Posted by Geoff NY on November 22, 2005 at 15:18:06 from (24.185.231.211):
In Reply to: Firing up a MD posted by Brad in WI on November 22, 2005 at 11:50:08:
I think you will find that the pump will start pumping with the throttle opened. This is part of the bleeding process as laid out in the owners manual.
Post a Followup
