Re: C-153 engine compression ratios?
Posted by Hermit on November 23, 2005 at 19:16:42 from (69.21.48.91):
In Reply to: C-153 engine compression ratios? posted by flem on November 23, 2005 at 17:17:23:
Looking at the engine specs, I didn't find the compression ratios but it does show the compression pressures. The gas has a compression of 180 psi and the LP has a compression of 185 psi. So there is a slight increase in compression ratio but not by much. Hard to say how much of a power increase you would have.
Post a Followup
