Re: hydro pump mystery
Posted by CNKS on November 25, 2005 at 19:13:31 from (204.249.178.138):
In Reply to: hydro pump mystery posted by fenton on November 25, 2005 at 07:49:07:
It MUST have either an o-ring or a normal seal. The seal will fit over the shaft into a machined area on the front of the pump. If I remember right, there is a recessed groove in the front of the housing that holds an o-ring in place, if you have that. I guarantee you if you look at the shaft you will see a groove where that seal has run -- unless you have a new or reconditioned pump. you may or may not need a speedy sleeve, depending on how bad the groove is. You do not need to disassemble the pump to replace the seal.
Post a Followup
