IH 340 U brakes
Posted by Fred Mills on November 26, 2005 at 18:20:59 from (216.93.118.114):
I need to rebuild or replace or adjust the brakes on my 1963 IH 340 utility. There isn't much info or detail in the shop manual. I would appreciate any detail procedures for replacing the disc and things to watch out for.
Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
