Re: IH 340 U brakes
Posted by Dellbertt on November 27, 2005 at 08:32:31 from (204.39.210.204):
In Reply to: IH 340 U brakes posted by Fred Mills on November 26, 2005 at 18:20:59:
Fred, I always learn as much or more from a parts manual than I do from a service manual. The pictorials and diagrams always show you exactly what order things go together and also give you the correct name for a part that you need.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
