Re: Farmall 656 gas problems
Posted by K.B.-826 on November 26, 2005 at 19:19:16 from (209.163.43.123):
In Reply to: Farmall 656 gas problems posted by bcook on November 26, 2005 at 09:44:57:
Where are you checking fuel flow? Do you have the line unhooked from the carb, or do you have a plug removed from the bottom of the carb bowl? If you've got the line unhooked from the carb, and the line is clear, you may have air locked the sediment bowl by removing it. Turn on the fuel and loosen the sediment bowl slightly until it starts to fill and fuel starts flowing out the line, then tighten it down.
