Super C iginition woes Part Deuce
Posted by Tom Yaz on November 27, 2005 at 14:15:58 from (69.166.181.31):
Ok to review I have new points,condensor,rotor,
and coil. Rechecked the points gap at .020 at
high point of seperation
Turned on ignition switch,
And proceeded to check for spark on both terminal
wires on the coil (the +,- wires)
The one that goes from the iginition to coil has plenty of spark, and the other which hooks to
the distributor and condensor also has spark I noticed when I tighten down the condesor connection.
To further test I cranked it over and put the
distrib end of the coil center wire close to the iron and got no spark.
Unhooked the condensor and repeated, no spark
During both these tests, I saw no spark between
the points.
What now?
