Re: Still having Mag problems on a model B
Posted by El Toro on November 27, 2005 at 17:00:11 from (205.188.117.73):
In Reply to: Still having Mag problems on a model B posted by Frank Stalfire on November 27, 2005 at 16:39:45:
Can you tell if the impulse coupling is snapping when you hand crank it. This is what causes a hot spark when hand cranking. You should hear a snapping sound when hand cranking. Make sure those points are set to .013" too. Hal
