Re: taking off m radiator
Posted by Haas on November 27, 2005 at 18:35:05 from (12.65.78.243):
In Reply to: taking off m radiator posted by farmallkid04 on November 27, 2005 at 18:14:16:
Two at the bottom,(If still original, these will have castle nuts and cotter pins). They are stud bolts that screw into the bottom of the radiator, so they may unscrew out of the radiator. There is a brace at the top attached to the gas tank support near the oil/temp gages. Fan shroud needs to come off, which is held by several small bolts. Also, you have to remove the steering shaft which goes through the top tank of the radiator.
