Re: Farmall A Plough
Posted by El Toro on November 28, 2005 at 09:47:19 from (152.163.101.13):
In Reply to: Farmall A Plough posted by MJ in the UK on November 28, 2005 at 09:08:28:
MJ, Click on Implement Photos under Galleries to your left. There's an A with a single bottom plow attached. You need to keep clicking on the next set of photos to reach #992-1007. The plow is the IH model A91.
I restored an A about 30 years ago and I have a picture of the same 16-inch moldboardplow mounted on the tractor. It's just a 3/4 side view & doesn't show all the attachment points. If we would have this forum 30 years ago I would've taken some closeup pictures.
We never had a tractor mounted plow on the farm until we had the 1950 Farmall C & it was a two bottom moldboard.
This plow wasn't that difficult to install
all the brackets were on the plow & I just pulled the tractor along side the plow & started hooking
brackets to the tractor. I sent several pictures
to men that had A's and were installing the same plow. Hope some will see your posting and will respond. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
