Re: Farmall A Plough
Posted by El Toro on November 28, 2005 at 11:53:47 from (152.163.101.13):
In Reply to: Farmall A Plough posted by MJ in the UK on November 28, 2005 at 09:08:28:
If you think you'll need a picture I'll make copy & send it to you. Hal
PS: It does show the mounting brackets under the tractor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
