Re: Still No Spark!!!!!
Posted by JT on November 29, 2005 at 06:24:53 from (70.226.210.68):
In Reply to: Still No Spark!!!!! posted by Short Bolt on November 28, 2005 at 21:24:45:
You are checking for voltage at the coil with a test light, are you getting 12Volts here? Even thought it is lighting a test light, it may not have enough voltage there to start it. I had a tractor a couple of weeks ago, one of the guys was using a test light, thought it had 6volts at coil,because it lit test light, so why no fire, found out it only had 3.4 volts, hooked a wire directly to coil from battery and it started right up and ran fine. Bad ignition switch. Might be something to check, especially if the fire to plugs are weak.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
