Still No Spark!!!!!
Posted by Short Bolt on November 28, 2005 at 21:24:45 from (69.21.20.3):
Still trying to get the 340 running. Done melted the starter down cranking it so much. Have tried 2nd set of plugs, points, condensor. still no run!Replaced coil again still no go! Took whole distrubitor and coil and plug wires off my running 340 timed it all up ,still won't fire a lick even got mad and sprayed either to it still no fire, not even a hick-up. checked with test light wire to coil hot ok! When she cranks the wire from - side dist flashes ok! dist to points lead stud flashes, points flash, very little spark at plug tip. carb floods, but no run not even a sputt! plugs gap .023 valves set .014 new rings, pistons, any ideas, while I'm waiting on new starter!!!!!!!!!!!!!!!!!!Thanks
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
