Re: Ajustable tie-rods for a 1949 Farmall Cub
Posted by gene bender on November 29, 2005 at 17:03:12 from (66.43.221.81):
In Reply to: Re: Ajustable tie-rods for a 1949 Farmall Cub posted by George the farmer on November 29, 2005 at 16:52:25:
OK i have had the problems also used wd-40 and a small hammer and tapped all along the length to get some penetration of the wd and finally got them loose but no fun at all. I have a friend who will let them soak submerged in water for weeks and usually they will come apart. His theory is that water rusted them and if you can soak long enough the water will free them. good luck like i said no fun at all.
