Re: Farmall M Just won't Start!
Posted by Janicholson on November 30, 2005 at 15:21:14 from (199.17.6.175):
In Reply to: Farmall M Just won't Start! posted by Keith M on November 30, 2005 at 14:46:45:
Fixing everything at once is problematic, if one of the fixes is incorrect there are now two issues ETC! However! I would pull out the sparkplugs and (using a squirt oilcan filled with 2stroke mix gasoline I would use one squirt in each cylinder then put in that plug finger tight. Then tighten all the plugs. Crank the tractor (neutral etc.) to see if it starts.
If it starts and dies, you have a fuel delivery problem. if not I suspect either compression (stuck valves) or spark timing/firing order. 1342 from front. Looking from rear toward front at the dist. If clockwise rotation of dist.
2 1
4 3
if CCW
3 1
4 2
good hunting, JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
