Re: Farmall M Just won't Start!
Posted by old on November 30, 2005 at 16:41:30 from (207.69.137.25):
In Reply to: Farmall M Just won't Start! posted by Keith M on November 30, 2005 at 14:46:45:
If it sat that long fill the cylinders with tranny fluid and let it sit a day or 2. Be sure to put the plugs back in so dirt etc don't get in to the cylinders. Then after it has set a day or so the pull all the plugs and crank the engine over to clear the cylinders. Put the plugs back in and see if it will start. You probably have stuck rings and that causes low compression and that cause lack of vacuum on the intake.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
