Re: Frozen Rear End - Revisited
Posted by F-Dean on December 01, 2005 at 07:06:18 from (209.247.222.96):
In Reply to: Frozen Rear End - Revisited posted by Robert Lorencz on December 01, 2005 at 05:27:37:
It may not be frozen from the temperature. I have been working off-and-on restoring an M and the rear-end "Froze Up" on it. However, when I towed it to my shop area, it broke loose. I suggest you drain and fill the rear-end/transmission (13 gallons) and then try pulling it. First, turn the front wheels all the way in one direction and pull in that direction on the front hitch so that one wheel is stationary and one is turning. Then repeat for the other direction. It worked for me! Good Luck!!!
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
