Re: Frozen Rear End - Revisited
Posted by Shaun Arms on December 01, 2005 at 10:09:45 from (68.156.64.5):
In Reply to: Re: Frozen Rear End - Revisited posted by Farmallkid From Ont on December 01, 2005 at 07:51:56:
Thick black rearend grease is really not a
good thing. When you put new grease in there
it should be the same color as motor oil. You
only get black grease from heat. It won't turn
black unless it has had excessive heat.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
