Re: motor swap????????
Posted by ChadS on December 02, 2005 at 09:34:18 from (66.228.96.137):
In Reply to: motor swap???????? posted by Geoff NY on December 02, 2005 at 07:57:20:
You would have to use longer frame rails to use the IH 6 cyl. Maybe off a 560,,, if the frame rail bolt pattern is the same as an M-560 to the bellhousing. The M-560 was the same bellhousing pattern for the engine plate, If your SW6 has a 3 bolt starter, you may get away with using a 560 flywheel and not have to change the starter ring, you would have to measure the backspacing from the engine plate back to the back edge of the starter ring. and see if the SW6 is the same as the 6 cyl. I know on the 460, using the small flywheel, it is 4 inches,, It all comes down to where your starter location is on the bellhousing,, if it like the 450-560, you wont have much trouble with the starter, but if the W6 is like the M bellhousing, you will have to do something with the starter ring, and check backspacing. It can be done, but have to know a bit more about your W6 to know what to use for parts. When I put the 6 cyl in a H, I used a 460 flywheel, removed the 460 starter ring, and cut the flywheel in a lathe to fit the H ring on the 460 flywheel. Then for the clutch,, its a 460 pressure plate, with a Super H clutch disk, wich kept the 10.5 diameter clutch disk, but had the H input shaft spline. Used the H throwout bearing, and workedlike it was made that way from the factory, so Im betting, there is a same combination of IH parts to do the same swap for the M-W6. If the 560 used the same diameter clutch as a Super M, you may be able to use a 560 flywheel, SM disk, and possibly put the SM ring on the 560 flywheel to line up. Sorry so long of a post,,, Im trying to remember all this without going to the books,,,, So, it comes down to which starter you have,,, 2 bolt, or 3. ChadS
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
