Re: C123 without water pump
Posted by El Toro on December 02, 2005 at 16:00:56 from (205.188.117.73):
In Reply to: C123 without water pump posted by Kevin Hood on December 02, 2005 at 15:18:30:
According to my manual the late production C's had
the thermo-sighoning system with a pressure type cap. They recommend the 165-190 degree thermostat. He should feel the radiator lightly
to see if it feels hot all over or has hot spots
and cool places. Radiator tubes may be getting plugged restricting coolant flow.
When I had an A it wouldn't heat up unless you were plowing. Hal
