Re: C123 without water pump
Posted by Kevin Hood on December 02, 2005 at 17:55:33 from (161.156.99.11):
In Reply to: Re: C123 without water pump posted by El Toro on December 02, 2005 at 16:00:56:
I was not sure if the thermo-sighoning had a thermostat.
Kevin
