Re: which farmall?
Posted by Ksfarmmer on December 03, 2005 at 06:33:41 from (24.255.226.14):
In Reply to: which farmall? posted by vinnie on December 02, 2005 at 15:09:16:
Size of your wallet makes a difference as well. The M and H should work fine for what you need. I wonder if a C might be smaller than you want for 50 acres. A pull type bush hog and disk won"t need a fast hitch. I found a Farmall 300 for about the same money that did have the fast hitch. With conversion arms, I can use smaller 3 point equipment. If I was you, I'd find something that you like and not worry so much about what other people suggest.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
