Re: White smoke and good compression??
Posted by El Toro on December 03, 2005 at 18:13:19 from (205.188.117.73):
In Reply to: White smoke and good compression?? posted by Pete7 on December 03, 2005 at 14:52:36:
Have you seen any bubbles in the radiator when the
engine is warmed up & idling? If you do, it could be a headgasket or cracked head. You can apply 4-5 pounds of air pressure to the radiator. Remove the sparkplugs & then crank over the engine to see if coolant blows out.
One of your sleeve's may have a pin hole & is leaking into the sleeve when the tractor is sitting. The seals on your sleeves are known to leak too. The coolant can then leak into the oil pan. The oil pan would need to be removed to check for this. I would drain that engine oil
with the antifreeze. It will remove the oil from the bearings & cause wear. Hal
PS: A new headgasket would be the easiest to repair. I would have the head magnafluxed too.
Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
