Re: White smoke and good compression??
Posted by RN on December 03, 2005 at 18:19:03 from (166.126.218.219):
In Reply to: White smoke and good compression?? posted by Pete7 on December 03, 2005 at 14:52:36:
White smoke for a couple minutes run may not be antifreeze- typical symptom of somewhat worn valve guides without seals. Oil leaks down from guides while setting, burns with white smoke exhaust for few minutes after start. Good rings so compression shows high and no more smoke when warm. Anti-freeze in pan on wet sleeve engine could be leak at base of cylinder instead of head/head gasket area- A,B,Cs are this type of engine design.
