Re: Timing a SA distributer Any suggestions welcom
Posted by Peabody on December 03, 2005 at 19:49:54 from (64.12.117.13):
In Reply to: Timing a SA distributer Any suggestions welcome! posted by scott#2 on December 03, 2005 at 18:16:11:
Funny thing about that mark. If you look in the Owner's Manual, the illustration makes it look like something that would slap you in the face. Not the case, in most instances. As others have said, get it to #1 TCD on compression stroke, you will be close, then clean the flywheel and smear some white paint around, it may show up. Even if it doesn't show up, you should be close enough to "in time" to get it to start, and then adjust time with the distributor. Good luck!
