Re: White smoke and good compression??
Posted by gene bender on December 04, 2005 at 00:36:32 from (66.43.221.81):
In Reply to: White smoke and good compression?? posted by Pete7 on December 03, 2005 at 14:52:36:
Best way i have found is to drain oil then drop pan. After a day or so look up in engine at bottom of sleeves and you should see which one is leaking as there will be a drop or maybe even a small puddle from which one if any o-ring is leaking. Your head may also the culprit and mite be rusted thru and letting oil in the crankase. Remember theseare 50ys old and bad water over the years does take a toll.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
