Re: 1486 no forward gear
Posted by the tractor vet on December 04, 2005 at 13:23:46 from (4.124.75.102):
In Reply to: Re: 1486 no forward gear posted by natedoggmotorhead on December 04, 2005 at 13:12:00:
You should have the special tool for the cover removal ,But if you can get and extra set of hands and remove the cover on the side of the rev. shifter it can be done just don't lose any pices . You will loose about 1 gal of hytran when the side cover comes off . My guess is that either ya sheared a key and pin or the high low shift fork broke if the shift linkage is moving back and forth . just becareful when you are bringing the top cover up and LOOK between the cover and case yea i know it is hard to get your head cocked to look but use a couple trouble trouble lites.
