Re: farmall 450 belt pulley
Posted by Wardner on December 05, 2005 at 06:09:51 from (4.154.246.31):
In Reply to: Re: farmall 450 belt pulley posted by Hugh MacKay on December 05, 2005 at 01:40:54:
Hugh,
I checked my parts book which covers M thru SMTA. All the belt pulley gearboxes are the same except for the early M's which had a different pulley control lever and shaft. That is the piece that engages the internal gears. Brackets and engagement rod also changed at F-28174.
I am not going to compare the SMTA thru 560/660 unless someone requests it. It seems likely that they are the same.
Basically, there are only two IH gearboxes produced at that time. One size for the M sized tractor and another for the H's and up.
