Re: Red-hot resistor - final - maybe
Posted by Bob M on December 05, 2005 at 12:45:12 from (69.205.112.3):
In Reply to: Red-hot resistor - final - maybe posted by Alannpa on December 05, 2005 at 11:27:38:
I concur with the advice of John T and Janicolson - don't use the field resistor! A voltage regulator working by itself is fully automatic. Incorporating the field resistor will only "confuse" the regulator - with unpredictable results.
And thanks for the feedback on what the root cause of the problem was!
