Re: piston compression question
Posted by gene bender on December 05, 2005 at 18:11:22 from (66.43.221.81):
In Reply to: piston compression question posted by super_m on December 05, 2005 at 14:51:43:
Wont be that much between the two biggest gain will be the larger bore this will also bring up another question what is the desired result. If you are building a puller then mite want different set-up alltogether.
