Re: double wheel weights on farmall h good or bad?
Posted by Steven@AZ on December 11, 2005 at 05:39:23 from (24.121.48.188):
In Reply to: double wheel weights on farmall h good or bad? posted by lekander883 on December 10, 2005 at 20:30:02:
By adding additional weight you won't damage anything unless you go the wrong way across the furrows in a field and get to bouncing - good way to break an axle.
What front end do you have on your H? Power steering? Just curious.
Don't let these guys scare you away from using your H, Grandpa fed cattle with an H (narrow front) and a Farmhand F10 loader for many years without trouble. Just use common sense, don't turn with the loader raised more than a foot off the ground, go slow, etc. Be safe.
