Re: double wheel weights on farmall h good or bad?
Posted by Allan in NE on December 11, 2005 at 06:55:16 from (148.78.243.24):
In Reply to: Re: double wheel weights on farmall h good or bad? posted by Dave in CT on December 11, 2005 at 06:24:21:
Mornin' Dave,
I can't ever remember "not" having an H under a loader. They work just fine, always have; maybe more so today, as they aren't big enough to do much else other than drag the yard once in awhile.
Only thing I did notice, was that the older I got, the nicer the add-on power steering came to be. :>)
That H's fifth gear is what made 'em nice to run to the other end of a half-mile long hay field.
And like I've said a hundred times before, don't forget to cinch up 'er belly 'cause they will pop. :>)
One thing I will say, I just cannot imagine using a trike front end under a loader tractor. When you get a big, heavy load 15' or higher up in the air, that thing sways around bad enough the way it is, even with a wide front.
Dunno, we all do it differently I guess, but Hs, Ms and loaders are just plain commonplace 'round here.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
