Re: TD6, MD, WD6, WD9 Air Cleaner interchangeabili
Posted by n9lhm on December 11, 2005 at 18:14:20 from (70.224.39.73):
In Reply to: TD6, MD, WD6, WD9 Air Cleaner interchangeability? posted by Doc Larry on December 11, 2005 at 15:57:16:
My MD parts book shows part numbers 54261D, 54274D, and 67120DA as part numbers for the "housed screen" assembly, with the 67120DA replacing the earlier numbers. The oil cup shows as 54265D. This is from parts manual TC-28D. Brian
