Re: Something's Eating My Condensors!
Posted by El Toro on December 12, 2005 at 16:26:49 from (205.188.117.73):
In Reply to: Something's Eating My Condensors! posted by Joe A. on December 12, 2005 at 16:08:16:
Are you using a ballast resistor between the ignition switch and the coil? If the coil is 6 volts, the resistor would drop the battery voltage
to the coil to 6 volts. Hal
