Something's Eating My Condensors!
Posted by Joe A. on December 12, 2005 at 16:08:16 from (4.89.129.167):
I have a 1964 I504 Utility with IH 12V ignition. It started missing at higher RPMs a while back. I took it apart and checked fuel, spark, everything. I finally replaced the condensor with a used spare and it ran fine. Problem solved, I thought. It ran for about 3 working hours and did the same thing, replaced the condensor with another used spare, and it fixed it again. So far (knock knock) it is still running (about 3 working hours right now). Where should I check if it does this again? Anybody have this happen to them before? Thanks.
Joe A.
Corydon, IN
