Re: Storing Tractors in Historic Barn
Posted by JB2 on December 12, 2005 at 19:56:05 from (72.56.121.128):
In Reply to: Storing Tractors in Historic Barn posted by PurdueAg on December 12, 2005 at 18:46:16:
Hi Purdue, my brother has a bank barn like yours but it was built in 1920s. It has two ramps and hay mows on either side of the ramps. The flooring in were the ramps are is 4" pine planks. The floor where the hay mows are is only 1" boarding. My brother goes in there with his IH 495 with 2250 front end loader and round bales. He piles the round bales as high as the loader will lift. You should check the beams at the foundation side were the ramps are build against the barn. Typically rain water does not drain away properly and the water seeps into the ends of the beams and rots them at the foundation end.
JB2
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
