Re: Storing Tractors in Historic Barn
Posted by PurdueAg on December 13, 2005 at 07:34:39 from (198.109.220.6):
In Reply to: Re: Storing Tractors in Historic Barn posted by PaulW_NJ on December 13, 2005 at 07:28:50:
Paul,
That's not a bad idea. My main concern was the height
and width of the doorway on the lower level. I could
probably get the C and F-12 in there, but not the H. But,
you're right, there's no reason I couldn't dig it out a bit! I
would feel much safer about that.
The property has a separate heated workshop with a
cement floor. That's where I plan to do the restoration
work. I just need the barn to put the finished tractors
and implements.
Thanks for the tip.
Tony
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
