Re: Storing Tractors in Historic Barn
Posted by PaulW_NJ on December 13, 2005 at 07:28:50 from (70.111.191.105):
In Reply to: Storing Tractors in Historic Barn posted by PurdueAg on December 12, 2005 at 18:46:16:
I have a bank barn that I am in the process of restoring. It is about 100 yrs old. Inside of the main door to the upstairs level on the top side, there are (true) 2x10"s laid crosswise to the floor joists, 10 feet long, on top of the 1x flooring, that run all of the way thru. I have been parking my Cub on top of that for a couple of years and it"s very solid. Of course a Cub is very light compared to your tractors. But as several have mentioned here, it"s not just the size of the beams, but how the weight is distributed and the condition of the connections between the beams. Bottom line is that with proper structural analysis, and perhaps beefing up the floor, you could do what you wish to do.
But why not store the tractors on the lower level? My lower level was dirt and partial concrete of various thisknesses. This summer I jackhammered out the concrete remnants, removed dirt to level out the ground, and am ready to pour a concrete floor in the Spring. Not only will you have a infinitely more solid base, it will be a much safer floor against fire hazard from any sort of metal work and sparks. Storing, and working on, old tractors on old wooden floors is as much a fire hazard concern as the weight issue.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
