Re: FOLLOW-UP ON SHORT
Posted by Kevin LA-CA on December 13, 2005 at 18:46:26 from (67.21.10.198):
In Reply to: FOLLOW-UP ON SHORT posted by RANGEL on December 13, 2005 at 10:27:49:
This summer I broke the field winding right where the winding clamped to the post/stud. I didn't hold the jam nut and stud turned too much and broke the winding.
I didn't see the earlier posts - don't know if you are drawing any current (i.e. see sparks). Could be an open like I had. Check post to ground with DMM. Probably should be <10ohm.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
